2 members (ranchojuan, baldeagle), 35 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#636302 04/09/2010 6:29 PM
What is the Reverse Polarity Switch, and What is it used for? I saw it on a 1942-45 wiring diagram. Thanks
It reverses the polarity of electricity going thru the ignition points, supposedly to reduce wear. It is mounted on top of the starter and is pressed every time the engine is cranked. It proved to be more trouble than it was worth and most were removed when they failed. The only reason I run one is for originality's sake.
I may not even have one!!!! Scary to think that I don't know! I'm rewiring my truck this weekend and I wasn't sure if it was needed. I'm using a Pertronix Ignitor and Coil. Thanks for the tip.
