| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | What is the Reverse Polarity Switch, and What is it used for? I saw it on a 1942-45 wiring diagram. Thanks | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | It reverses the polarity of electricity going thru the ignition points, supposedly to reduce wear. It is mounted on top of the starter and is pressed every time the engine is cranked. It proved to be more trouble than it was worth and most were removed when they failed. The only reason I run one is for originality's sake. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | I may not even have one!!!! Scary to think that I don't know! I'm rewiring my truck this weekend and I wasn't sure if it was needed. I'm using a Pertronix Ignitor and Coil. Thanks for the tip.
