2 members (baldeagle, Hotrod Lincoln), 71 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#63628 07/29/2006 3:36 AM
Could someone tell me how to decipher a serial number off of a turbo 400 transmission. The number above the pan on the drivers side reads 13C136562. It is a 400 transmission. I don't know what it came out of. Any help? I need to replace the torque converter.
#63629 07/29/2006 10:43 AM
I do not know how to read the number you have provided. I believe it is a VIN derivitive number providing a matching number (or not) to the engine.
I believe the info you need is on the ID tag attached by the factory to the transmission. It will have a number like 68 CA 375 and should look like this:
http://corvetteforum.net/c3/1970registry/04102_th400tag.jpg
If it came out of a chevy, this should help.
http://www.novaresource.org/trans.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
