5 members (klhansen, 69Cuda, FAST55, dt235sd, 2-Ton), 88 guests, and 5 robots.
Topics128,050
Posts1,055,667
#635598 04/07/2010 9:58 AM
Hi,
How do I get the bellhousing off my 235 - I haven't looked yet, I'm just looking for some advice to an easy change over from manual clutch to the hydraulic arrangenent I have on my truck.
Thank you,
Laine
3B Offline
Hy laine snook, you will have to remove the clutch and flywheel to get to all of the bellhousing mounting bolts, and there are two dowel pins to properly align the bellhousing before any bolts are installed. The bellhousing will have to be pried/tapped off of the dowel pins once all the bolts have been removed, hope that helps.
