1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hi,
How do I get the bellhousing off my 235 - I haven't looked yet, I'm just looking for some advice to an easy change over from manual clutch to the hydraulic arrangenent I have on my truck.
Thank you,
Laine | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy laine snook, you will have to remove the clutch and flywheel to get to all of the bellhousing mounting bolts, and there are two dowel pins to properly align the bellhousing before any bolts are installed. The bellhousing will have to be pried/tapped off of the dowel pins once all the bolts have been removed, hope that helps. | | |
