4 members (DaveV, Paul_WNC, Rusty Heaps, Otto Skorzeny), 76 guests, and 0 robots.
Topics128,050
Posts1,055,646
#635594 04/07/2010 7:46 AM
B46
Offline
I've tried to attatch the cable to the trannie many times. Unfortunatly, the only successful part of this is the screwing on of the cable. I would sware that something right inside the trannie that sends the spin through the cable is broken. The tip of the cable is find, but I believe the femal end in the trannie is worn. Is this common and is there a way to repair it?
Thanks.
Brandon
1988 4Runner: SR5 ~ 3.0 ~ 5-Speed ~ No Sway Bar ~ 3-Point Rear Seatbelts ~ KC Daylighters ~ EGR By-Pass
1946 Stovebolt: Rebuilt 216 ~ 6V ~ All Stock
Extras: Stuff for my signature that just wouldn't fit.
B46 #635603 04/07/2010 11:40 AM
hook it up, run it to the cab and go for a short distance holding the end of it. if its turning then its working
be sure the drive cable inside the case extends out enough to engage the tranny drive. Insert the drive cable only and try to turn it, if it turns freely there's a problem. If it doesn't turn then the drive cable is probably too short, not engaging the tranny drive.
Ed
