0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Weather is getting nicer, so getting the urge to start working on the door hinges of my '57 3100, but could use some advice/ guidance.
It looks like the lower hinge pocket has rusted through from what I can see, is this something that should be/ can be fixed prior to replacing the hinge pins? If so, what is the process, parts from where, cost, etc? Right now my driver door seems to drop a bit after opening, so thinking maybe the pocket is what is causing the problem??? Thanks guys. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, that area is prone to rot - patch panels are available, both the face with the opening and the pocket box behind, like hereBill | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Bill,
Thanks for the info. Thoughts on how to find someone to perform the repair? Type of welding suggested/ required, tolerance/ setup, etc? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hafta ask around for a good bodyman, look for a place that does restoration, or real metal work, as opposed to insurance claims where they just re & re panels, they'll have a good MIG and know what to do with it, not real difficult for someone with the skills
Bill | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Is this beyond the capabilities of the average Joe with a MIG? I have a buddy who has done a lot of work on his own car [replacement panel fabrication and welding/ engine & drivetrain fabrication adn welding) but I don;t want to ask if it will be something in the end we both wish he had not started... | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Guessing no response means NO? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | didn't see the last question  it isn't the easiest job to tackle, but someone who's done similar should understand how to go about it, just a matter of cutting out and welding in, but note that hole positions the door, so it needs to be pretty close Bill | | |
