| | | Forums66 Topics128,156 Posts1,057,019 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I know that the center bolts are done first 15-20 ft pds, and the outside last 25-30 ft pds, but what size drive fits in the space so that you can get the socket on there. I have two torque wrenches, but they are 1/2" drive. Will a 3/8" drive fit, or do you need a 1/4" drive. The outside bolts won't be a problem. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | That torque range is usually found on a 3/8" driver. However, given the space limitations, I usually just pull them pretty snug using a long box end wrench. Doug | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I use a 3/8' drive witha crows foot and/or a box adapter to get to the tight ones.
Bill Burmeister | | |
