1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#635132 04/05/2010 10:15 PM
Howdy, I was wanting to know if anyone has a kit for hooking up two tale lights with turn signals, and the signal lever, for my 51? I also need the switch for brake lights too.
I'm just trying to do this for right now until I can rewire the whole truck.
I went for a drive the other day, and almost was rearended. Seems people don't know what the ole"arm out the window" is for anymore!
Switch assembly - call them to see if it has flasher and flasher-holder
flasher
right tail lamp assembly (painted - other styles are available)
right tali lamp bracket (painted - other styles are available)
front parking-lamp conversion kit
Instructions come with the Switch Assembly (supposedly)
Cletis's Tech-Tip should help with figuring out the wiring.
Riding in the Passing Lane
Kits for trailer lights are readily available at a pretty cheap price. That will give you the 2 lights & wire.
1972 Chevy c10 Cheyenne Super
