0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#634987 04/05/2010 7:55 AM
I went to NAPA and picked up a new radiator cap for my truck.Its a 58 GMC 250 with a 270, it has the original radiator.I got the part number that I needed on NAPA online and went and picked it up.Its a 7 pound like the one I had but it wont press down enough to screw on.Any ideas? What other numbers/brands do you use?
Jeremy
581ton #635001 04/05/2010 11:10 AM
Can't provide a specific part number, but if you measure the depth of the radiator neck from the top of the flange to the seat where the gasket seals, then buy a 7# cap that is about 1/4" longer than that measurement, it should work. There are at least two different neck depths, and it sounds like you've got the cap for the longer one.
581ton #635257 04/06/2010 4:30 AM
Thanks for the info.I never knew of the different neck depths.Back to NAPA lol.Thanks for the help again.
Jeremy
