| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | I went to NAPA and picked up a new radiator cap for my truck.Its a 58 GMC 250 with a 270, it has the original radiator.I got the part number that I needed on NAPA online and went and picked it up.Its a 7 pound like the one I had but it wont press down enough to screw on.Any ideas? What other numbers/brands do you use? Thanks, Jeremy | | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Can't provide a specific part number, but if you measure the depth of the radiator neck from the top of the flange to the seat where the gasket seals, then buy a 7# cap that is about 1/4" longer than that measurement, it should work. There are at least two different neck depths, and it sounds like you've got the cap for the longer one. Jerry
| | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | Thanks for the info.I never knew of the different neck depths.Back to NAPA lol.Thanks for the help again. Jeremy | | |
