3 members (Jay R, Phak1, walter74), 70 guests, and 4 robots.
Topics128,180
Posts1,057,164
Members48,465
Has anyone replaced the sliding glass windows with one piece glass in AD Suburbans. Were can one buy the rubber to hold them in. Rubber I have bunches up in corners. Any help would be appreciated.
RoseB
You can have automotive glass cut to just about any size and shape you need, while flat glass. Cut out a cardboard template, have glass cut to match.
Here two sites which carry a great variety of window molding:
Click On "Universal Parts"
Click On "Order Online"
Billyray
1948 GMC 3 Ton Flatbed
1952 Chevy 1/2 Ton Panel
1956 Chevy 3/4 Ton NAPCO
RoseB, firstly welcome to the Stovebolt.
This seems to be a common conversion on account of availability of good serviceable,original 'burb' parts.
As Billyray mentions any good glass shop can template and cut new glass for you.
The most common seal to use is called Claytonrite rubber.
It's exactly the same seal used on the back cab glass of AD pick-ups and COEs.
This has a black rubber lock strip,or you can go to a chrome look insert if you prefer the 'Deluxe' look.
If you make the templates yourself,the glass shop will make the necessary adjustments to the glass size.
Claytonrite is an 'H' section so the glass has to be 1/4" (approx) smaller than the aperature itself.
The 'bunching' you refer to is caused by the tight radii.
1/4" x 1/8" Claytonrite should work and any bunching should disappear once the lock strip is installed.
Gentle heating with a 'hot air' gun sometimes helps too.
I hope this info is of use to you.
More pix on Flickr.
Try Steele Rubber Products. They may have the gasket material for you.
1946 GMC Project
"Back-in-the-day Restore"
I'll second that,in fact I need to get a windshield rubber from Steele.
I found out about cheap repops the hard way!
More pix on Flickr.
