1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#634859 04/04/2010 6:04 PM
on a 54 that has been converted to 12v which terminal on the fuel guage gets the shunt? the one with the red tab or the other one. thanks.
Wes,
The resistor/reducer goes between the positive/power/source lead and its post on the gauge.
Can you still read your tag? It should tell you which lead goes to that post (source or sender lead).
In 1954, the post behind E (Empty) is the source/power post.
Last edited by tclederman; 04/04/2010 10:44 PM. Reason: changed "sender" to "gauge" on the first line
Leo Offline
Moderator
Moderator
I should change mine? It's near the fuel tank but not hooked up to power yet.
Leo #634893 04/04/2010 10:25 PM
Wrong place! The purpose of the resistor is to reduce the 12V power to the guage down to about 6V so it has to be on the battery side of the guage, not the sender side.
Sorry guys, my meds got me. I changed "sender" to "gauge" on the first line above.
" . . . between the positive/source lead to its post on the GAUGE"
That would be the post behind "E" Empty on a 54/55.
I can't stop the drugs for a few days, so I will stop the posting.
there is a brown wire that goes to the sender and a red wire that I assumed was the power to the guage.I hooked the resistor to the back of the guage where there was a red tag but that was the full side of the guage. So I guess I have them backwards on the guage? the red wire goes to the E side and the brown to the sending unit goes to the full side?
The resistor goes inline with the lead that supplies the power. In other words you disconnect the power lead, connect it to one side of the resistor and connect the other end of the resistor to the gauge.
1951 1 Ton Completed
yea OK I get that but which terminal on the back of the guage gets the power The one lined up with the empty or the full? thanks
neswes #635007 04/05/2010 12:05 PM
Previous post w/picture of connections.
'54 fuel gauge picture.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #635316 04/06/2010 12:23 PM
Leo Offline
Moderator
Moderator
My gauge has a small piece of a red plastic tag on it, most of it is missing. Thanks for that photo, OlBlue.
