3 members (Bill Marlow, tclederman, 52Carl), 54 guests, and 3 robots.
Topics128,090
Posts1,056,028
Members48,432
#634567 04/03/2010 2:40 PM
dwm
Offline
Is there any difference between a driveshaft from a 3/4 ton and 1/2 ton? Are the trans. yokes the same?
dwm #634696 04/03/2010 10:45 PM
It is probably dependent on which engine and transmission is installed more than 1/2 ton vs 3/4 ton suspension. The long bed trucks normally have a 2 piece driveshaft while short beds have the 1 piece version. Some of the compound low 4 speed transmissions have a bolt on yoke against the transmission, while others have a conventional slip yoke. Powerglides, Turbo 350's and 3 speed manual (and early 4 speed passenger) transmissions normally share the same (smaller) yoke, while Turbo 400's and never 4 speeds like a Super T10 and late Muncies share a common (larger) yoke.
There's generally 2 trunnion sizes, large and small for both GM and Ford applications. If you end up with a mismatch, most parts houses carry a "combination" joint which has small caps on one cross, and large caps on the other, and they work fine:
http://www.dennysdriveshaft.com/p46...ination_u_joint...spicer_greaseable.html
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
dwm #634892 04/04/2010 10:06 PM
dwm
Offline
Thanks for the information. New to rebuilding trucks and trying to avoid costly mistakes.
