3 members (GIJOE298, Gray_Ghost, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
#63482 07/26/2006 10:58 PM
The 261 has a higher lift cam, valve guide heights above head surfaces are spec'd higher, and the spring tension is higher.
Is it truly fine and dandy to put the 235 head on a 261 block without changing these items?
Mike Barnes
1950 GMC 1-ton pickup
I understood that you were supposed to use the 261 head gasket to locate and drill the steam holes in the head due to the siamesed cylinders of the 261.
3B Offline
Hy guys, if my hot rod memories are correct, that particular swap will result in an increase in compression ratio also, hope that helps.
3B Offline
yeah, got an 235 (848) head on the 261 - runns like a champ.
Verry poppular combination in the 50es.
Frank
Yes, have the gasket and am drilling the extra holes but they are not really mandatory. However with a more aggressive lobe on the cam and more lift I can definate see that the guide height and spring tensions could be very important.
Am I the only guy who thought of this?
Mike Barnes
I have installed in my 235 an Isky full race cam and inner valve springs. Installed chrome moly tube pushrods also. They have been in it probably 30 years now and I did not have to do any real work for extra clearance. Somewher around, I have the cam spec card.
I may be mistaken, but i seem to recall that the Canadian Pontiacs from the early '50s used a 261 with a 235 head as factory equipment.
That swap will increase the compression ratio, due partly to the smaller chamber, but also from the larger piston displacement. As far as the valvetrain goes, I don't think that the guide hight will make a difference, you'ld be using 235 valves. As long as the sprins were compatible with the cam, there shouldn't be a problem.
Bill Burmeister
Thanks for your replies.
Mike Barnes
Longbox,
You're only partly mistaken. "Early 50's" Canadian Pontiacs had a flathead six but starting in 1955 GM Canada used the 261 with the 848 head until 1962.
Curt B.
You Tube
I knew it was some time in the '50s or '60s, thanks for clearing that up.
Bill Burmeister
