| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I have drip on a brake line that I can't seem to repair....does anyone know of a thread sealant that will hold up to brake fluid? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Did you try to loosen and than retighten the fitting a few times many times that will seat the flange on the fitting ,the tread on the fitting does not seal the line it's the fit between the line flare and the fitting that seals the brake line so it could be the flare or the fitting is bad or not lined up ,try to loosen than retighten frist ,you may have to reflare the line or replace the fitting look at both you should see where the two are fitted and see the problem.
Pete | | |
