Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, Peggy M, 55shaker), 30 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#634443 04/02/2010 11:56 PM
1953 216,rebuilt carb,new plugs(gap@40),new wires, cap,rotor,new flamethrower coil(1.5ohm internal res)new Pertonix in dist.timing mark on ball.still idles rough. some advice on what next? thanks
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
Mr.Giant #634464 04/03/2010 1:08 AM
Check that you didn't cross your plug wires.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #634471 04/03/2010 1:37 AM
no they are correct 1-5-3-6-2-4- and on the rite plug
Mr.Giant
Mr.Giant #634482 04/03/2010 2:32 AM
Carburetion specialist
For testing purposes, try removing the pertronix and flamethrower, and use stock components. You just might get surprised.
Jon.
The Carburetor Shop
carbking #634514 04/03/2010 4:42 AM
Mr. Giant writes, "still idles rough."
I like this advice carbking up there gives, put it back together the way its supposed to be.
Readers really need to hear the idle to make decent guesses.
There are two types of rough idling. One is repetitive, the other is random. Both point to certain types of problems.
A repetitive rough idle keeps time with your rpm. This occurs at very regular intervals, precisely the same amount time between rough spots like a clock ticking.
A repetitive rough idle points to a problem with a specific cylinder. Low compression, bad plug, faulty wire, arcing in the distributor cap or, most likely, a leaky valve. Your big bolt GMC odometer has probably rolled over once or twice. High milage on a GMC usually means leaky valves. Reason for this is modern gasoline, since around the Seventies, is blended to destroy your engine. I think this is a conspiracy between Chevron and NAPA.
Have your engine idle, pull off one spark plug at a time beginning with number one cylinder. If the rough idle worsens dramatically, not the bad cylinder, slip your spark plug wire back on. Should you come across a cylinder when pulling the plug wire only slightly worsens the idle, this is your bad cylinder. Might have more than one bad cylinder. This is a cylinder which is most likely suffering a leaky valve. Might be a plug, a rocker arm adjusted way too tight, a bad compression ring, but this problem is specific to this cylinder.
A random rough idle cannot be timed, simply comes and goes with no discernible pattern. This is like a mouse running loose inside your intake manifold. Mouse stops over here, runs over there, stops somewhere else, completely random.
This points to an electrical problem, a carburetor problem, a leaky intake manifold gasket, plug going bad, dirty points or a hot failing spark coil. More often this is a points problem or a spark plug problem. However, an overworked coil will do this, a coil missing a step down resistor or simply plumb worn out. Might be a bad spark plug connector at the distributor cap or at the spark plug. Carbon fiber spark plug wires, if bent, if damaged, will mimic a random problem.
If a random rough idle, pulling off spark plug wires, one at a time, will make no difference, not a specific bad cylinder.
Overall, repetitive problem or random problem, this comes down to three major components: fuel, compression and ignition.
A fuel problem usually kills your engine or robs your engine of power. Typically this is "smooth" problem, not a rough idle.
A compression problem, such as a leaky valve, will always be repetitive, you can set your watch to this. This is a very reliable repeating problem.
An ignition problem will drive you nuts. Only cure is a step-by-step correction. Start by inspecting, cleaning and setting your points. Check the rotor for looseness and arc damage which erodes away the copper tip. Look at the cap for obvious problems like too short of a center electrode, broken or chipped electrodes, loose fitting. Check the overall condition of your distributor, no looseness anywhere. Check for a possible vacuum leak which is random, maybe a hose flopping around.
Replace your condenser, always. Those do not simply quit working, those gradually go bad often causing a random "miss" in your engine, like your engine stumbles for a moment.
Be sure to carefully set your timing. Usually this acts like a fuel problem; robs power or causes backfiring, not random.
Spark plug wires and plugs, no way to test, simply replace those. Same with the coil.
Two types of coils. One requires an external resistor, the other has an internal resistor. One or the other, has to be right. When an external resistor is missing, a coil will heat up and slowly begin to fail. Works great while cool or just warm. When hot, problems show up and as heat increases, problems become more severe. This is usually the lacquer coating on the wire windings inside frying causing minor short circuits; does not quit but the spark periodically becomes very weak.
One other often overlooked problem, a corroded wire somewhere, like your key to coil wire. Corrosion changes properties slightly with temperature. Shaking of a corroded connector will cause a random like problem; voltages drops, wavers, spikes.
A reliable check for a repetitive problem is running a compression test with a good quality compression tester. This is actually the best way. Pay attention to how quick or how slow compression bleeds off for each cylinder.
A reliable check for a random problem is simply flip a coin and go for it, could be just about anything.
Oh yes, brand new parts is not a guarantee of having good parts. Never assume a brand new part will work correctly, most often a new part is broken right out of the box; Murphy's Law.
Probably Chevron and NAPA are behind this broken new parts thing.
Billyray
1948 GMC 3 Ton Flatbed
1952 Chevy 1/2 Ton Panel
1956 Chevy 3/4 Ton NAPCO
Billyray #634577 04/03/2010 3:19 PM
This is, as said, a useful test, but only if 2 different things are true:
1. the original parts are both in excellent condition, and installed correctly
2. the replacement parts are defective, broken, worn out etc. and/or improperly installed or adjusted.
The original parts are not "better".
panic #634600 04/03/2010 4:40 PM
Mr. Giant, here are some comments from a boy who installed a Pertronix ignition system:
"When I started the engine the first time (it did start, but did not run well, at all) after installing this system, the timing had shifted to about 30 degrees BTDC and needed to be immediately adjusted."
"After a little driving, the engine started missing badly to the point where the car was undrivable. The idle was terrible and felt like one cylinder was not firing at all. By pulling the plug wire to the #1 cylinder I determined that it was not firing, but, to my surprise, I found that if I let the wire arc across to the #1 plug, the cylinder would begin firing and the idle would smooth out."
"With my plugs gapped at .045 in, the engine smoothed out and ran on all cylinders. The Pertronix Ignitor instructions, by the way, do not mention spark plug gap at all...."
Billyray
Billyray #634615 04/03/2010 5:24 PM
From the Pertronix support page (this also used tobe mentioned in the installation instructions but it is no longer there)?
"What should I gap the spark plugs to?
The Ignitor has no set specification in which the spark plugs should be gaped at. Every engine responds differently to spark plug setting. In most cases increasing the factory recommended gap by .005 improves the engine performance."
Billyray #634617 04/03/2010 5:26 PM
Here are the top problems with a Pertronix ignition I found out on the web. Surveyed about 100 pages of articles returned by Google. These are ordered by which problem occurs most often:
One or two cylinders not firing because a design flaw in the reluctor magnets. When the circular reluctor magnet is rotated, the next cylinder or next two cylinders quit firing.
A stock coil cannot handle a short charging time because of a short dwell cycle of a Pertronix. A weak spark is produced. Stock coils usually burn out in time.
Coil overheating because of the short dwell cycle of a Pertronix. Cure is to install a high performance coil with an internal resistor, then hook up a full 12 volt lead.
Cross-firing between cylinders which have spark plug wires touching each other for a long run. The spark charge leaps from one plug wire to an adjacent plug wire.
Too narrow of a plug gap. Most frequent setting is .045 for a gap to cure this problem.
In all cases, reinstalling the stock ignition system cured problems.
Billyray
Billyray #634628 04/03/2010 5:49 PM
tclederman writes, "...this also used tobe mentioned in the installation instructions but it is no longer there?"
Don't know. I have never personally worked with a Pertronix. A majority of people love those systems but there are enough problems reported to exercise some caution.
Reads to me when a full ignition system is upgraded, coil, wires, plugs and the Pertronix, there are no problems. Seems an "all or nothing" thing on this.
My best guess is the shorter dwell radically alters the timing point compared to a stock ignition. Might be this is customers do not think to carefully time their engines after installation.
Again, when "all" is done right with a Pertronix, appears to be no problems. I am taking those negative reports with a grain of salt, no telling what people actually do in cases like this.
For old inline six cylinders, I stick with stock ignition systems, not going to get much of a performance boost out of those little engines. For high performance small blocks, I go all the way to a MSD ignition system; those make a dramatic positive difference.
Billyray
