5 members (lumbersawyer, Nick in Manitou, Wally / Montana, Sjm, Peggy M), 135 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#634598 04/03/2010 4:26 PM
when setting timing on 235 w/ solids should the rotor be pointing at # 1 when the triangle is on the pointer or the ball?
neswes #634616 04/03/2010 5:25 PM
The ball is the timing mark and the triangle is usually TDC/UDC
thanks Tim
neswes #634637 04/03/2010 6:43 PM
Actually the triangle is used for cam timing and is not TDC.
My Blog
Here is the description of using the triangle to check cam timing from the Chevrolet Shop Manual. It seems that this procedure will work only with the stock camshaft (and matching flywheel?)
Hoyt
