5 members (TUTS 59, Cosmo, Youngin' Tut 59, Chip O, 1 invisible), 45 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#634526 04/03/2010 6:13 AM
Okay, I own a 1949 3100 parts truck and a 1950 3100 fixer-upper... Both have the same spare tire mount which is behind the rear axle. It appears to be a slide rail of some type. It is on and angle. It looks like you would have something connected to the wheel, then slide it up inside this rail. then fasten it down? My factor assembly manual and shop manual both show something other than what I have. does anyone have info on how I'm to put a spare on?
1950 Chevy 3100
with matching trailer
More pix on Photobucket
gmindel #634604 04/03/2010 4:48 PM
There are a few pictures of the spare under bed carrier on these pages. This is as it would be factory installed on a 1950, 3604, the half ton would be very similar. The only difference in the half-ton is the rear upper rail rear bracket is a little taller and the front mounts to the cross member a little differently
http://www.pbase.com/dennygraham/the_box&page=1
http://www.pbase.com/dennygraham/the_box&page=2
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
