2 members (Tinker5, klhansen),
178
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63457 07/25/2006 5:46 AM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Gents,
I'm putting a freshly rebuilt late 235 in my '53 3/4 ton. Not wanting to spend any more money than I absolutely have to after that $1900 rebuild, I have a nice NOS Carter WA-1 carb, which has the right mounting hole spacing for the 235 intake, I'm wondering if it would work well on the 235 until I can afford a YF? The WA-1 I have is for an Olds 238 flat six, and it has auto choke. Thanks for your thoughts. | | |
#63458 07/26/2006 3:58 PM | Joined: Nov 2002 Posts: 2,776 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,776 | The Carter WA-1 is an excellent carburetor.
HOWEVER!!!
When migrating O.E. carburetors from one application to another, it is important to do some math. As a general rule of thumb, one can do plus or minus 3 percent displacement.
An example: say you have an O.E. carb that originally was used on a 200 CID engine (200 means easy math). 3 percent of 200 is 6. Thus this carburetor could probably be successfully migrated to a similiar engine/vehicle from 194 to 206 cubic inches.
What is a similiar engine/vehicle? A similiar engine/vehicle would be a combination of an engine of the same general type (6 or 8 cylinder) with roughly the same maximum RPM. A similiar vehicle would be roughly the same weight.
I show WA-1's used on Oldsmobile 230, 238, and 257 CID sixes. If your carb is from a 230 or 238, it will probably work. If from the 257, you will probably experience low RPM issues.
Now about spending more money. Carter (and Rochester) used velumoid gaskets during this period. Carter quit using the velumoid about 1963 or so. These gaskets shrink over time when they are dry. ALL N.O.S. Carter carburetors from this time period should have a repair kit installed prior to attempting to use the carburetor. How do you feel about fire extinguisher residue all over your new engine?
Personally, I would suggest selling the Olds carb to an Olds person, and applying the sale price to a YF rather than spend money on a carb which you will eventually replace. MOO.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2020 Posts: 2 Moderated | | Moderated Joined: Feb 2020 Posts: 2 | I have a NOS Carter WA-1 413S that I want to use on my 1955 235 engine. Please advise settings that should be used for best results.
1952 Styleline
