Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, 1 invisible), 41 guests, and 1 robot.
Topics128,003
Posts1,055,244
Members48,418
#634421 04/02/2010 10:57 PM
http://i913.photobucket.com/albums/ac339/Lilbro60/008.jpg
What do these numbers tell, if anything, you about this carb?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #634437 04/02/2010 11:40 PM
PapaJ asks, "What do these numbers tell...."
Tells me you have a decent camera and tells me you are wigging out over something you should not.
Simply a number to identify the base throat. Could be 216 versus 235, might be where the vacuum port exits, could be the throttle linkage style, no choke, auto choke, probably all of those.
Your number is not really related to the carb itself rather is related to what type of base sits under the carb. This is just for configuration differences in engines.
Your important number is stamped on a metal tag attached to the top part of your carb. This is the "model" of carb for buying a rebuild kit.
Billyray
1948 GMC 3 Ton Flatbed
1952 Chevy 1/2 Ton Panel
1956 Chevy 3/4 Ton NAPCO
Billyray #634462 04/03/2010 12:59 AM
Just wondering, because I don't have a number tag on my carb. I do know that I have a 235 from '56 but, the carb, when looked up at autozone, shows a picture from a '62 era chevy truck.I don't know if there is any other way of telling what carb rebuild kit I need to purchase.
1953 Chevy Two-Ton
PapaJ #634666 04/03/2010 8:56 PM
Riding in the Passing Lane
Those are easy to order by application as the didn't change much. The 59 on back had the fuel line go in the front & the air cleaner clamped to the neck. The early 60's up had the fuel inlet on the side with a big nut & built in filter. It had the air cleaner mount through a bolt in the center of the carb. There is a different kit for each one.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #634699 04/03/2010 10:57 PM
PapaJ, here are two photographs (in one) for you.
Cluster Of Carbs
216 size on your left, 235 on your right. There are no differences between those carbs above the base throttle device below each carb. Red dots show a minor casting change, but no difference in behavior nor rebuild kits.
Those red dots tell me the 216 carb way over on the left has a much later 235 carb mounted on the cast iron base throttle. Tops of carbs and the bottoms are interchangeable, sorta.
Looking at the bottoms, 216 left, 235 right, you can see a difference in throttle throat size and a difference in the spread of the mounting bolt holes. A 216 is smaller for both.
Nonetheless, you can interchange tops, the carb itself, between 216 and 235 bases. A rebuild kit will cover both carbs, 216 and 235, sorta.
Most kits have base manifold gaskets for both sizes. Some kits are different, either 216 or 235 but not both. Generally, 1954 and earlier will be 216, 1955 and later will be 235. However, there is a crossover in 1955 year for catalog listings, have to watch this. If you can, order a generic kit, a kit which specifies way back to the Forties and up to the early Sixties. Those usually have both manifold gaskets.
Even if you buy a wrong kit, the only "wrong" thing will be the manifold gasket. You can make your own very easily, nothing to this, nothing special, just match up any vacuum grooves or holes, same for both carbs, then shrink or spread your bolt holes. If your throttle throat hole is a tad bit too big, this will not hurt a thing, makes no difference on these tiny engines.
For trivia, I often buy a half dozen of these carbs off Ebay to mix and match, and to have small parts which are sometimes missing, like choke cable and throttle cable clamps. Always good have a few extra parts carbs, cheap enough to buy. Never know when you will have a leaky float or a rusty butterfly.
In this case, I will build two carbs for a Fenton dual carb intake. As you can see my 216 carbs and my 235 carbs are not precise matched pairs; those red dots. When done, I will have two very nice matching carbs. This Fenton intake matches up with Fenton exhaust manifolds, no need to grind away at an intake manifold to match the two, like mixing an Offenhauser intake with Fenton exhaust headers.
This 216 dual carb setup will be bolted to a 235 engine. Matches up fine save for the intake port size, 235 is slightly larger. No problem, adapter rings are available or the intake manifold ports can be bored out.
Order you a "generic" kit. I think Jim Carter carries those. Don't panic if your manifold gasket is wrong, make one or buy one individually. No sweat, all else is the same.
Billyray
