0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63433 07/24/2006 8:15 PM | Joined: Apr 2006 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 16 | Does anyone have an idea where I might find a new ring gear for this engine? Or........ a suitable substitue? 133 teeth on a 12.5" diameter flywheel are the specs. | | |
#63434 07/24/2006 9:04 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Because a 6 cylinder normally stops in one of three positions the flywheel teeth will only be bad in three spots. If they are not to bad you can remove the ring and turn it one third of a revolution and reinstall it.
If you think it is beyond this, you can flip the ring around and use it from the other side. You may need to bevel the leading edge of each tooth if it was that way stock.
See the USA in your vintage Chevrolet! My Blog | | |
#63435 07/24/2006 11:57 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Dave,
Wouldn't you have to rotate it one sixth of a revolution to make sure it didn't end up in one of the three bad spots? I kind of assume they would be one third of a crankshaft revolution apart.
Northwest Transmission Parts in Ohio advertises flywheel ring gears in Hemmings. | | |
