6 members (Bwana-Jim, J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE), 101 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#632187 03/26/2010 1:43 AM
I'm ready to install the cab back on the frame of my 53 AD. I have the bushing and shim kit but can't seem to find a tech article on how to do this properly. The site search didn't seem to help. Anyone know where I can find instructions?
The assembly manual has all the measurments thats what I used when I reinstalled my cab back on the frame
If you need the measurments I'll look them up and post them
Pete
Pete
Thanks for the offer but that sounds like a lot of hassle for you. I thought I saw a detailed description written by a "Bolter" sometime in the last year but found nothing in the site search.I bought the kit from Jim Carter but they didn't publish a tech guide for that on their site. I know this is critical to getting the fenders and hood to line up properly.
Dan
The shop manual spells it out clearly enough that a specific tech tip seems unnecessary:
Floor to frame at front mount = 1 53/64” (1.828”) to 1 57/64” (1.890”)
Rear floor support to frame rail = 49/64” (.765”) to 53/64” (.828”)
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0102.htm
IMO to mount it you need 4 friends, a pair of 4 x 4’s, and beer. You guide them into position and slip the front bolts thru and then buckle up the rear shackles. If you’re really clever you can make blocks of wood like the dimensions above to set it on and that will tell you where you are.
To add: notice the entire tolerance of .062". This means your cab should be plus or minus only 1/32" in relation to the framerail which seems pretty specific to me.
You Tube
Curt B.
Thanks so much. Just what I needed to know when I needed it.
Dan B.
Jim & Caroline
