| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63400 07/23/2006 8:42 PM | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I am putting an open driveline in my 1952 1/2 ton. I just bought new springs from Benz springs and will be running original height and not lowered. The truck will look original but have modern running gear because I need to use this as a daily driver and need to be able to make long trips in the truck. I have a 283 and a TH350 trans to put in. The original motor has long been gone. Many people have said to use a 70's to 80's 4X4 rearend but everyone I have measured is too wide plus they are expensive where I live in Klamath Falls, Oregon. This truck will not haul very many loads. So I found a 3:43 rearend out of 70's something El Camino that is the perfect width for the right price. Yes I know it is 5 on 4 3/4 but I was going to change the front to disc brakes and can match that bolt pattern. Questions: 1) Because the El Camino was a pickup "of sorts" will this rearend haul some light loads when I need to use the 52 as a truck? I am going to run skinny radials on new 6" wide rims. 2) It seems a lot of guys are putting in 3:08 ratios for the gas mileage. If I put in 215/85/16 tires the 3:43 in effect becomes a 3:19 ratio. 2087 RPM at 55 mph and 2467 at 65 mph. Will this be a decent compromise between economy and power or should I look for a 3:08 and run regular height tires? 3)If I run regular height tires (28") will my mileage suffer much? 2234 RPM at 55 mph and 2640 at 65 MPH. You guys are great and I apreciate any and all "opinions" and suggestions. Thanks, Wayne | | |
#63401 07/23/2006 9:21 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think the 3.43 gears with tall tires would be about right. The 283 with auto. is not a real high torquer. The el-camino rear end could handle the weight but the brakes arn,t very big. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63402 07/23/2006 11:21 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Sounds like a pretty good and economical plan. Certainly the Elco rear will handle your light loads and there isn't a dimes worth of difference between the 3:19 and the 3:08, you'd probably not even notice it. | | |
#63403 07/24/2006 2:24 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I used the 3.08 rear from under a '73 Chevelle wagon under my '55 1st Suburban. The GVW of the wagon was within a hundred pounds of the Suburban, so I figured the capacity and brakes would be okay.
At the same time I installed front disk brakes using a kit designed around 70's GM mid-size parts so I can ask for '73 Chevelle stuff at the parts counter.
I also swapped to a dual master, again using '73 Chevelle, and used the combination valve from that same car. I figured the weight distribution of the wagon compared to my suburban would be similar enough that it would work, and now almost four years later I'd say I was right. Not sure it would work as well on a pickup.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
