2 members (Shof, crenwelge),
178
Mod | | | Forums66 Topics128,281 Posts1,058,487 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | this thing is brand new,bolted to a 385 .at hiway speeds [2100 rpm] about every 20 miles the tac drops about 400 rpm [1800 rpm],runs like that about 20 miles then back up to 2100 .while its in this phantom 5th gear i cant kick it down into 4th i have to gear down to 3rd then into 4th[od] i ve been told its the shifter cable [my mechanic is losing his 5 star status ] opinions thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | it might be the Throttle Valve cable, which what controls the downshifts. Try readjusting it. There may also be an issue with the torque converter lockup. At highway speeds, it should remain in lockup, not go in and out.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | so if it dosnt stay in lockup is that a warranty issue | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Disconnect the electrical plug on the left side of the trans. & drive it. If it works without it hooked up then it is a problem with the lockup. You may not want to mention to the trans. place that you did this. It won't hurt anything but he could use it for a way out. My trans shop says you don't have to run a lockup if you don't want to but it's better to have one. There are several ways of controling lockup. Different kits & different shops use different systems. If it is a lockup problem it could be the controls or inside the trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
