3 members (Oswald, joe apple, jmoore), 127 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
I took my 52 1/2ton in for a lube job today. When they lifted the truck up, the rear part of the front spring separated from the shackle by about 1 inch. Is this normal? It looks like the leaf has a u-shaped bend that goes around the bottom part of the shackle. The end doesn't look like it's broken. The one on the other side looks about the same, but it didn't separate when it was jacked up.
Looks kind of scary to me.
My dad always told me, "Don't force it, get a bigger hammer".
Sounds like you have a broken spring bolt. Replacement is the best plan and if one is broken the other is probably bad too.
Riding in the Passing Lane
It's near normal. The second leaf is curved around to keep things from getting away if the main leaf breaks. There are clamps that hold the leaves together. Posibly they are missing. Universal ones are available but it's not a big deal.
1972 Chevy c10 Cheyenne Super
Sounds like its broken, Spring eye should wrap lower bolt.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Could you get a photo for us to see?
On my 54 1/2 ton the top leaf of the front spring wraps around the rear shackle bolt, and the next leaf is cup shaped and only wraps around the bottom half of the shackle.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Here's a photo of the spring with the truck jacked up by the frame. Now that I looked at it a little closer, I'm thinking the leaf that is supposed to wrap around the spring shackle bolt is broken off. The one below it has the end that wraps around the bottom of the bolt as a safety measure. And it's a good thing it does blush
Dropbox Public folder
You've got options.
You can replace the springs with new ones available from most any vendor or your local spring shop.
You could also replace them with Posies Dual-Flex springs to soften the ride and lower the truck a couple of inches.
You could also replace just the broken main leaf ( available from Classic Parts ) and take the opportunity to clean and repaint the springpacks. I've done the latter two and was/am happy with the results for both trucks.
regards,
Leon
You definitly have a broken main leaf.
Years ago that happened to my 54 1/2 ton, and a friend of mine replaced that leaf for me. It wasn't too difficult, and it worked good for 30-some years. Now the complete springs are getting replaced with new like-originals due to wear.
Samantha
1954 Chevy 3100
Follow in the DITY
I bought a replacement leaf,shackle, and spring bolt from the vendor you suggested. The parts came in a few days. I'm going to have the local spring shop do the work. Thanks for the info.
