10 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,689 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63365 07/23/2006 10:33 AM | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Here are the NAPA part numbers for inner and outer wheel bearings to fit 56-59 1/2 ton. You can cross reference them to cheaper suppliers most likely. Inner PGB PB52 or BRG B52 which is also pinion bearing Outer PGB PB67 or BRG B67
NAPA $23-$67
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
#63366 07/23/2006 1:37 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Paul, B52 and B67 are numbers that work for any brand - also, the outer is sometimes still listed under it's original number, B01 and the inner grease seal is Chicago Rawhide #18772 or NAPA #49412 Bill | | |
