| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | Did a total rebuild on my 261 engine just started putting fluids into it seems that the head gasket is leaking on both sides checked the torque on the head bolts which were tightened in sequence a little at a time to 80 ft pounds is this common does the engine have to warm up to seal or do i have a problem? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy gregs 52, I think we have a problem. Did you have the block and head checked for cracks before rebuilding? was this engine a runner before the rebuild, or did you buy it as a rebuildable core? | | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | did you check the head and block against a straight line to make sure they weren't warpped. I don't know off hand what the older engines can tolerate but 5-7 thou is in the ball park of too much. Also did you use a scraper to remove the old gaskets or some kind of abrasive disk? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am pretty sure that your head bolts should be torqued a lttle tighter than that. However the leak is very unusual. It is almost like there is something preventing the head from sitting down properly. | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, gregs 52 ,from your description, it sounds like something is trapped between the block and head.(IE, old head gasket not cleaned off, head gasket shifted on assembly, that flat washer you could not find on assembly, wrong head gasket or installed the wrong way, etc.) Remove head and check.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
