6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#633223 03/29/2010 10:35 PM
I'm having trouble keeping the door latch adjusted on a 58 Apache. I can adjust it and it works good let the truck sit and it may or may not close.
rdrunner #633304 03/30/2010 1:43 AM
new door seals? not getting the striker tight enough? cab sagging from rotting mounts?
squeeze #633436 03/30/2010 12:58 PM
Thanks Bill. The door seals are new but we have checked the fit for interferance and that's good. The cab mounts are good and have all been adjusted. The latch in the door is new from Brothers, we even put the old latch back in to try. The striker is tight and we marked it when the door was closing good and it doe's not move.
We can get it to close good and it may last for a week or 2 and then acts up sometimes while just sitting in the shop for a period of time.
Any other thoughts suggestions??
