8 members (carbking, Gdads51, Wally / Montana, klhansen, NJC, 2-Ton, 55shaker, Joe H),
46
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I ordered a new speedo needle for my '53 GMC. When I pull the speedo, I'd like to do a simple rebuild on it. Right now what's left of the old needle bounces radicaly, and the speedo makes lots of noise. I will be replaceing the speedo cable, but can any one give me some pointers on rebuilding the unit? Thanks | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Can't help with the rebuild but I can give you a word of warning. Don't toss your old speedo needle like I did. I didn't look close at the replacement needle I purchased. When I finally got around to working on the speedometer I found out the "replacement needle" was just a cover. You need to use the mounting parts from your original needle. Chuck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I took my '54 GMC speedo apart when I refaced it. There was a brass plug covering an oiling hole. I removed the plug and the packing material and blew carb cleaner through it. After blowing the cleaner out of it I oiled it, put the packing back in and oiled it. I sealed the hole with silicone.
I also took the number wheels apart and refaced them. I took a scribe and marked a line on each wheel between the 0 and 9 for a guide to where to put the new numbers. When you clean them the old numbers will wash off leaving no indication where the 0 goes.
| | | | | Joined: Mar 2009 Posts: 14 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 14 | Cletis,
What sort of oil did you use, and how does the unit work on a chilly morning?
Mike
1953 3600 350/700R4
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used 3 and 1 oil. As far as how it works, it works great in a drill motor. I need to replace the drive unit in the tranny before I can see how it works on the highway. | | |
