0 members (),
309
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 81 New Guy | | New Guy Joined: Feb 2010 Posts: 81 | http://www.64moneypit.pages.qpg.com/6066chevytrucks/id4.html has the best year-to-year model change descriptions I've seen. On that site, for 1964, it lists several cosmetic changes and new options available, but the only mechanical change I see was the addition of self-adjusting brakes. So... If I convert a '64 to power disc brakes, will I lose the self-adjusting feature, or will I be adding self-adjusting disc brakes? For that matter, if I add power disc brakes to a '63, will I be giving it self-adjusting brakes? Still learning... Thanks. Steve. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | yes you will.....discs are pretty much self adjusting! | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the self adjust or manual adjust is just on the shoes, so with out them it won't matter. the rotors uses a inferior method of runout for adjustment.  | | | | | Joined: Feb 2010 Posts: 81 New Guy | | New Guy Joined: Feb 2010 Posts: 81 | Great. Thanks, guys.
So given that I'm going to replace the drum brakes with disc brakes, there will be no real mechanical difference between the '63 and '64 truck for me. The differences will all be cosmetic, like the grill, the headlight bezels, and the windshield.
Right? If so, I'll begin searching for a 1963-66 truck instead of 1964-66.
Thanks. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The 63 does not have self adjusting brakes. IF you add disc to a 63 you still have to adjust the rear brakes. You could retro fit the rears for self adjusting brakes. It may be a non issue if you decide to change the rear axle for better gear ratio.
The 64-66 are self adjusting, and adding disc to the front, doesn't change anything as far as brake adjustment goes.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think you are right on, not much mechanical difference. changing the rear over to self adjust is pretty easy i think. but really the manual adjust is pretty simple, i wouldn't let it scare you off. you'll always have the "powerful" rotors up front where most of the stopping power will be. i think the 63 cabs look a little cooler anyway with the dogleg windshield. good luck in finding one. | | | | | Joined: Sep 2009 Posts: 21 New Guy | | New Guy Joined: Sep 2009 Posts: 21 | I have a 64 GMC 3/4 ton pu and it does not have self adjusting brakes on it.Dont know if its a GMC thing or maybe 1/2 ton verses 3/4 ton. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | my 64 chevy 3/4 ton has self adjust. i junked a 65 jimmy 3/4 ton one time that had them too, best i remember. my 63 1/2 ton has manual adjust on front and self adjust on back since someone swaped out rear end like larry said above before i got it. | | | | | Joined: Feb 2010 Posts: 81 New Guy | | New Guy Joined: Feb 2010 Posts: 81 | Thanks, guys. What about putting disc brakes on all 4 wheels? I know lots of modern cars still have drums in the back, and most of the stopping power is in the front. Would it be worthwhile to put disc brakes all the way around? I want the truck to be as safe as possible, but that might be overkill. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I haven't looked into that seriously, seems like a lot trouble and money. Particularly if you consider that most of the weight is transferred to the front. I'll be interested in what others post. This post recently came up on inliners.org; http://www.praisedynobrake.com/The poster was quite happy with ceramic brakes he purchased from them, and their customer service was excellent. I'll definitely have them in mind for my next brake job. Here's the post; http://www.inliners.org/ubbthreads/ubbthreads.php?ubb=showthreaded&Number=56223Larry
