2 members (k2handyman, TooMany2count), 66 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#632825 03/28/2010 6:59 AM
Does anyone have any formulas or procedures for removing wiper scuff marks on a windshield. I'm not talking about scratch gouges, just the old wiper scuff marks you see on most old cars and trucks.
Jon D #632826 03/28/2010 7:06 AM
1000 grit wet sand with dish soap & water. Be gentle!
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Jon, assuming you can't feel the scratches too much with your finger nail,you may be able to reduce the scuffing with a fine cutting compound.
What are your goals? Is it originality,or cost effectiveness?
I assume the glass you're referring to is in one of your trucks.
Bear in mind glass for ADs is relatively cheap,so it all depends on how much you value your own time and labor.
It can take considerable time and patience to polish glass and depending on how deep the scratches are will determine the final result.
You can reach a stage where you get distortion at the areas that are polished due to the amount of glass removed.
Laminated glass is by far the easiest to polish on account of its relative 'softness'.
I suppose as a 'glass guy' my choice would be obvious,but the final decision would ultimately be yours.
More pix on Flickr.
Jon D #632887 03/28/2010 2:55 PM
Ex Hall Monitor
Ex Hall Monitor
Most shallow marks can be polished out. I'm not an expert but I have seen it done. I can't tell you the exact grit of abrasive that was used but it was done in several steps with each step being a finer grit paper/polish. I can caution you to not concentrate just on a small area or you'll get a distortion like a fun house mirror effect from "cupping" the glass.
Tiny #632932 03/28/2010 6:32 PM
Good analogy Tiny! grin
More pix on Flickr.
I polished out my wiper marks with moto-tool with a buff wheel and compound (wetted with water) from the local auto glass company. They gave me a small amount free.
SimS #633162 03/29/2010 4:24 PM
Thanks everyone. One guy says to use Cerium Oxide, make it into a paste with water. I believe this is the same thing that Eastwood sells. It costs about $8 on Ebay.
Jon D #633220 03/29/2010 10:30 PM
Tip; Mask everything with sheets or covers other than the glass you're polishing.
You'll see why when you start...if you're using an electric buff that is!
It works well but can(will)be messy!
More pix on Flickr.
