7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl), 109 guests, and 0 robots.
Topics128,051
Posts1,055,764
#631830 03/24/2010 8:32 PM
So I am currently working on a 1958 Chevrolet Apache with a 283 engine and 3 Speed transmission. I started cleaning all the grease and dirt off the throughout bearing fork and discovered a bronze color paint.
Is this correct and original, if not what color should it be?
Mine is the color of metal..... I don't thing that part was painted originally.
58' 3200 235 3-speed/OD
It should be a raw metal with no finish. If you go that route you will probably want to put some sort of a protective finish on it.
Bruce
My Trucks
Stuff I Collect
Rust!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Apprentice
Apprentice
Mine is grease colored, do you mean this is not how it should be. Back to the drawing board.
You cannot measure a man by where he sits in comfort and security, but where he stands in times of adversity and danger.
