| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have an original grill (1953 1/2 ton Chev)that is riveted together. It is already painted body colour but I want to paint the inner bars gray. Do I need to take the grill apart or is there a better option? | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I dis-assembled My grill to send out for chroming the outer bars, and You will do a better job if taken apart... I also painted the inner bars using argent silver instead of the gray...Bill B | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Bill stated, taking apart the grill for painting would seem to be the best way to get a good result.
If you are interested in original color-names, in 1953 the radiator grill-bars (inner surfaces) and hub caps were painted Thistle Gray.
Bumper facing were gray (most likely Anvil Gray).
Argent Silver was the inner-bar color on painted grills on 1954 trucks that had the Commercial Red exterior color. This was supposedly used because the Commercial Red bled through the Thistle Gray. Argent Silver might also have been used on Red trucks' inner grills in 1953.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | OK, so I get a quart of Thistle gray and I'll use an ounce or two. How close is Thistle gray to anvil gray, may as well do the bumpers too, what about the rims? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Anvil Gray is just a little darker than the Thistle gray. The tonal difference between the two grays is less than the difference between these two grays: Mesa Gray & Dove Gray (closer to the lighter gray). | | |
