0 members (), 87 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#632638 03/27/2010 4:38 PM
Can a 20 Dayton and a 22.5 Dayton be used together on the same hub as a dual set? Tires would be 10-20 and 11-22.5. I'm wondering because I need extra spares for a trip. Thanks much. Mert
gto57 #632664 03/27/2010 6:54 PM
Below I've linked the Yokohama catalog that has a section on when and how it is safe to combine tires of different construction. Go down to page 16 of the pdf file.
The outside diameters of each are close enough that that aspect shouldn't be a problem.
Back in the old days, the manufacturers commonly showed tube type and tubeless combos pictured together on the same axle in their catalogs. That was before radial tires became the norm in tubeless sizes. Today you can get radial tube type as well as tubeless, so maybe it's no different. The basic message in the catalog link is to not combine dissimilar tire construction on the same axle. Stu
http://www.yokohamatire.com/tires_commercial/truckBusRefGuide.pdf
