0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#632352 03/26/2010 4:35 PM
Have a leaking seal on the pto 15/16" OD. outshaft but I have to ID the pto gearbox to find the seal first. Transmission is a SM-420 with a 6 bolt aluminum case pto box. Numbers stamped into it are 204489 and C 393171 No manufacturers name anywhere and I couldnt find an answer in the archives soo... Any ideas on the manufacturer? Or other methods of IDing it?
Thankyou, John Drabik
It is likely an old Chelsea if it's aluminum but that really doesn't matter. If you pick the seal our of the case you will then be able to match it up dimensionally.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I have an old PTO for my coe, the local 6-states driveline was able to ID the pto I had and even had the seals I needed in stock to finish the PTO rebuild.
Matched up a seal for it yesterday. The original was a one piece affair with the seal and three bolt flange molded as one.
I melted the old rubber out of the flange and found a seal at a local shop that fit. RTV`d it into the flange installed it and have seen any drips so I guess its a success.
