| | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | I just got my switches in and i am wondering how the brake lighr and the dimmer switch mount exactly to the firewall. my truck had a new firewall when i got it so i do not have any holes or old switch locations to go by. pictures would be great. thanks fellas | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Is this on your '27, your '49 or? | | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I bolted my dimmer switch to the floor just a week ago. There should be holes through the floor that correspond to the holes in the switch. It would be easier to fasten the 3 wires to the switch before the switch is in place, unless you have long skinny fingers. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The brake light switch mounts so that the switch arm is held against the pedal arm. When brakes are applied the switch arm swings forward to close the contacts. | | |
