5 members (RLB, 1955 1 Series, Thomaslb, 52Carl, Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
U
U Offline
I just got my switches in and i am wondering how the brake lighr and the dimmer switch mount exactly to the firewall. my truck had a new firewall when i got it so i do not have any holes or old switch locations to go by. pictures would be great. thanks fellas
Is this on your '27, your '49 or?
U
U Offline
sorry about that 53
Leo Offline
Moderator
Moderator
I bolted my dimmer switch to the floor just a week ago. There should be holes through the floor that correspond to the holes in the switch. It would be easier to fasten the 3 wires to the switch before the switch is in place, unless you have long skinny fingers.
The brake light switch mounts so that the switch arm is held against the pedal arm. When brakes are applied the switch arm swings forward to close the contacts.
