1 members (edgardo), 79 guests, and 3 robots.
Topics128,057
Posts1,055,808
#630902 03/21/2010 8:40 PM
guy,
do any of you know of a vendor who sells LED tail / brake lights ?
i have a set on my boat trailer, and would like some that will fit like factory for my 57.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Bill Burmeister
thanks guys. would like to get something brighter than the 1157 old skool bulbs.
would these work, from autozone ? just pop them in, no modification..
http://www.autozone.com/autozone/ca...bright+LED+bulb&brandName=Jam+Strait
leonard
I actually tried bulbs similar to the AutoZone ones you show, didn't seem to make much difference, due partly to the bulb location on the housing (too low) and the fact I've got blue dots which blocked the light. The secons one you have linked should work very well, as the leds are spread over the entire lens. The Technostalgia kit works similar, exept that you use the existing lens. I did a minor alteration to mine so the blue dots still work.
Bill Burmeister
thanks bill..
when i finally get my regular 1157's to work properly, i really want to go with some led's, probably the classic parts one's.
thanks
leonard
I had given thought to LED bulbs and wondered if they would improve the lighting.
I know part of the problem with led bulbs is that they project the light which makes the reflector in the lamp assy. less useful, along with less overall light dispersion.
It would be nice to know if the bulb idea really improves something or is just another HP idea that sounds good.
Please let us know what you determine after installing those bulbs.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Bill Burmeister
Originally Posted by LONGBOX55
wow. looks pretty bright bill. thanks.
i like all your pics of the old nascar / drag cars.
leonard
I finally gave up on the original type tail lights. My first upgrade was to replace the the two small lamps with an 1157. That moved the light output from "birthday candle" to "weak flashlight". Following drivers still seemed a bit startled to see an elderly truck stopped ahead with no warning. I just put round trailer lights back there, and I've yet to see a surprised driver behind me. This truck is a daily driver and I'm willing to sacrifice some originality for less bodywork.
Mike
1953 3600 350/700R4
Jim & Caroline
very inventive caroline. i like it much.
thanks for the info and pics.
leonard
just got a set of these form advanced auto.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Super-Bright-Red-LED-Automotive-Bulb-Pair-Jam-Strait_6120509-P_N3157A_A|GRP2044____#
once i get my new turn signal switch installed next weekend, i will see how they work.
leonard
