Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Rusted Nut, 59 fleet, Otto Skorzeny, 1 invisible), 236 guests, and 5 robots.
Topics128,282
Posts1,058,497
Members48,490
How much oil should you have coming up in the valve cover area. I cannot get oil pressure to register at my guage. I have replaced the oil pump (tested it on the bench with a drill and primed it) I have replaced the guage and the tube going to the guage. I can spin a drill on the oil pump with the distributer removed and see a tricle comming from the rocker arm shaft and a slow stream comming from the return line at the rocker arm shaft. If I remove the tube that goes to the guage I just get a slow drip. I even blew all the lines out with compressed air when the oil pan and oil pump was removed. Any ideas? I'm out of them
If it's broke hit it harder!
I forgot to add the engine is a 216 and the truck is a 1953 3800 (1 Ton)
