3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | Started draining all the old fluids from my truck today and when I took the drainplug out of the oilpan I had to poke thru a thin layer of black/silver goo to get it to drain.It wasnt really metalic,more like a grease.Found the same thing in the bottom of my oil filter canister.I dont believe this is from the engine.The truck has been in my family since new and it has set most of its life in a barn.Ive heard stories of old paraffin based oils,not sure if any of its true or not but could this be from that?Do I need to take the pan off and clean it out or is this something normal to find on an old truck?58 GMC 270 ci Thanks, Jeremy
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Straight mineral oil had a lot of paraffin or wax in it and it did settle out over time. What you have found is very common. The black/silver is carbon, not metallic. This is also common and nothing to be alarmed by. I wouldn't even bother to remove the pan. The paraffin will become liquid when it is hot. Change the oil, run the engine hot and pull the plug while its hot and let it drip a while. You might want to then drive it a few miles and drain it again. | | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | Thanks,thats what I was hoping to hear.That was some pretty nasty stuff,kinda worried me. Jeremy | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i found the oil that had been sitting in my 262 hudson engine for years looks brand new and golden on the dip stick but, i was advised to pull the pan because some of the contaminates that settled out might clog the pick up when i start it. i still haven't got around to doing it, but i think i might do it just to be sure. i am not saying you are wrong at all crenwelge, i don't know. i wonder if mine would be fine, but i hate to take a chance. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Pulling the pan on a 58 GMC is quite simple. It might be worth peace of mind to drop the pan, but I wouldn't try to clean anything else. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | but I wouldn't try to clean anything else. when i got the ashton i pulled the pan because the gasket leaked. all i found was four inches of sludge on the bottom and a broken lock washer in the sludge. i guess the washer was a part the engine didnt like so it spit it out.  | | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | Im going to drop the pan just for piece of mind.The gasket is less than 10 bucks and thats cheap insurance.Might go ahead and put a new oil pump in while im in there.Where is everyone getting thier oil pumps at? Jeremy | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i was pretty amazed how new that oil looked up top in my 262. i had never seen anything like that before, was told it was common on old oil to seperate out like that. who knows if it would be a problem or not. | | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | I have two part numbers for oil filters for the 270.One is WIX 51001 and the other is WIX 51503.The 51503 is to tall to fit.The 51001 fits but it is a strugle to get the top back on the filter can.Is this normal or is there another filter? Thanks, Jeremy | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The AC number is P112, Fram is C100. Wix 51001. Any of these will fit. | | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | | | |
