| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | I have a '49 Chevy half ton with oringinal 216 motor, I'm adding an AC external oil filter, I wanted to know if I could buy a filter cartridge at a local auto parts store, and if so what is the part number, also i was wondering where the oil lines hook up on the block, i have three different spots where it looks it could go. Thanks Pat. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Filter is a Fram C4P or equivalent. Filter inlet hose (side of filter) connects to the fitting that drives the oil pressure gauge. Filter outlet (bottom of filter) hose goes into block directly above the oil distributor cover next to the exhaust manifold.
Ed
| | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | Thank you very much Ed for the info I'll give it a shot. Pat | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Here is an instruction sheet for 1940-49 AC filter installation. It is for a car but it would be the same for the trucks back then. http://www.pbase.com/dennygraham/image/123022930/large Here is a sheet for a Walker aftermarket oil filter, same hook up as the AC. http://www.pbase.com/dennygraham/image/123022547 Cartridge is a NAPA 1100 or a Wix PC100 Denny Graham Sandwich, IL
Denny G Sandwich, IL
