9 members (Otto Skorzeny, MickeyP, Biermann, jmoore, Shade Baby, TS3600, BC59, MikeStone1953, Gdads51),
114
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 13 | Hello,
I have a 1953 GMC longbed (102-22) with a 3 speed torque tube tranny.
There is an additional short driveshaft/ball assembly that connects the yoke from the rear of the tranny to the torque tube on the axle.
Does anyone know where to get the gasket for the short driveshaft ball ??
The ball that is facing toward the tranny side (has a grease fitting) is a little bigger than the other ball gaskets which come with the typical u-joint gasket sets.
Any info would be appreciated.
Jay L.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Jim Carter lists the drive shaft extension that was GMC only as a ME470. I would call them and ask them if they have the seal. I would think if they have the drive shaft, they would have the seal also. 1 816 252 5857. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Look about midway down on this site. Bill modified the short shaft housing to accept a modern more reliable seal. Might be of interest to you. http://www.53gmc.com/39101.html | | |
