5 members (Nuts&Bolts, Joe H, baldeagle, Shade Baby, dt235sd), 66 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#631884 03/25/2010 12:10 AM
I have a '49 Chevy half ton with oringinal 216 motor,
I'm adding an AC external oil filter, I wanted to know if I could buy a filter cartridge at a local auto parts store, and if so what is the part number, also i was wondering where the oil lines hook up on the block, i have three different spots where it looks it could go. Thanks Pat.
stanley49chev #631924 03/25/2010 2:48 AM
Filter is a Fram C4P or equivalent. Filter inlet hose (side of filter) connects to the fitting that drives the oil pressure gauge. Filter outlet (bottom of filter) hose goes into block directly above the oil distributor cover next to the exhaust manifold.
Ed
Forty9 #631991 03/25/2010 11:57 AM
Thank you very much Ed for the info I'll give it a shot. Pat
Forty9 #631996 03/25/2010 12:54 PM
Here is an instruction sheet for 1940-49 AC filter installation. It is for a car but it would be the same for the trucks back then. http://www.pbase.com/dennygraham/image/123022930/large
Here is a sheet for a Walker aftermarket oil filter, same hook up as the AC.
http://www.pbase.com/dennygraham/image/123022547
Cartridge is a NAPA 1100 or a Wix PC100
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
