1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 125 | I'm at the point where I'm about ready to remove the rear springs (with overload leafs) on my 1 ton. I'm currently digging the dirt and grease off and am looking for how to remove the springs from the brackets on the frame but haven't found anything obvious so far. I've found a couple of small bolts and nuts but they don't seem to be what's holding it all together. My questions are; what am I missing and how do I get the springs off? Thanks in advance. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Remove the small nuts. With a punch drive the small bolts out. Support the truck and axle best you can to remove all tension from springs. Use a slide hammer in the grease fitting holes in the ends of the spring pins to yank them out. Alternately use a big punch or steel bar and drive the pins out, this can be done from either side, even from inside the frame going out.
Grigg | | | | | Joined: Jun 2005 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 125 | Grigg, Thanks; I knew it was something pretty simple that I was missing but just was up against a wall trying to figure it out. I'll give it a try this weekend. Due to economic conditions I've done virtually nothing on ol' Frank for over a year but am finally getting things rolling again.
Make sure you give me a holler next time you get out this way. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a piece cut from a gear shift lever that is about 18 inches long. I use it as a punch to drive the pins out when removing rear springs. It is long enough I can both hold it and avoid banging my hands up real bad in the process.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I use an old king pin from a 1/2 ton truck to use as a punch to hammer out the rear spring pins thru the holes that are on the inside of the frame. | | |
