5 members (Hanks custodian, Phak1, Lostbuthaulinass, homer52, Wheelie), 138 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#631489 03/23/2010 6:02 PM
I would like to take a 1952 1.5 to 2 ton chevy front clip and put it on a 52 suburban. will the hood and fenders match up ? and has anybody done this and are there pics of the project.
The fenders, hood and grill are different on the larger trucks than what your Suburban came with. Can you do this? Yes. I can't imagine why you would want to. What are you trying to accomplish by making this swap?
OldSub #631670 03/24/2010 4:45 AM
You could graft the frame onto the sub frame and the front clip will but up to the cab. But it will look way out of proportion. I would rethink the whole idea before you build something that looks like its been in a demolition derby.
crenwelge #631878 03/24/2010 11:18 PM
I think the front fenders & hood are about 5" longer. And the wheel arches are larger, made for 7.50/8.25 x 20" rubber.
But hey...did you ever see one of the COE 'burbs...you could be ahead of your time.
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
JD49 #632317 03/26/2010 2:31 PM
I am wanting to make a 4wd dually with 35" tires and want to keep it as low as possible to pull my boat. I have two 52 subs and a 52 1.5 ton the rear fenders are what is scaring me.
I have seen pickup rear fenders trimmed to bolt to a panel or Suburban the way the stock fenders do, but making the fender much wider. I have also see big truck fenders that appeared to have small truck wheel openings grafted into place.
I haven't seen, but can imagine someone taking pickup fenders and replacing the wheel opening with that of a big truck. Take that same pickup fender and trim the lip that bolts to the bed off and then trim and drill so it fits over the dual wheels and your huge tires.
I would not go so far as to call that a recommendation, but its the idea that occurred to me as I thought about what you';re trying to do. What you do with it is up to you.
OldSub #632643 03/27/2010 4:50 PM
Oldsub thanks never thought of swapping openings great idea. I am trying to get this idea thought through as much as possible so when I get done with a 32 five window for a friend I can start on my own project
