| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | So I am currently working on a 1958 Chevrolet Apache with a 283 engine and 3 Speed transmission. I started cleaning all the grease and dirt off the throughout bearing fork and discovered a bronze color paint.
Is this correct and original, if not what color should it be? | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Mine is the color of metal..... I don't thing that part was painted originally.
58' 3200 235 3-speed/OD
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | It should be a raw metal with no finish. If you go that route you will probably want to put some sort of a protective finish on it.
Bruce | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Oct 2007 Posts: 15 Apprentice | | Apprentice Joined: Oct 2007 Posts: 15 | Mine is grease colored, do you mean this is not how it should be. Back to the drawing board.
You cannot measure a man by where he sits in comfort and security, but where he stands in times of adversity and danger.
