1 members (Gdads51),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | i have a 62 235 and i can not get the cam out, it moves out about 1/4 of an inch but then stops. the distributor is pulled,the retainer bolts,pushrods are pulled and the lifters are pulled up 1/2 an inch. as far as every other engine i've worked on goes it should be able to slide out. any hints?????? | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | You mention the retainer bolts? Is that for the thrust plate? If so I think that's everything.
58' 3200 235 3-speed/OD
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the crank is not turned just right the cam will hit a counter balance.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | i tried turning it over and pulling, maybe i will have to give it a try tomorrow. yes those are the bolts for the thrust plate. thanks alot guys. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Note that the Chevrolet Shop Manual recommends that the crankshaft gear be pulled first. This allows for easy rotation of the camshaft to clear the crankshaft counterbalance weights. Otherwise, the crank has to be rotated to eliminate the interference until the cam gear is no longer engaged with the crank gear. Hoyt | | |
