1 members (qside), 72 guests, and 2 robots.
Topics128,049
Posts1,055,741
#631620 03/24/2010 2:19 AM
Apprentice
Apprentice
i have a 62 235 and i can not get the cam out, it moves out about 1/4 of an inch but then stops. the distributor is pulled,the retainer bolts,pushrods are pulled and the lifters are pulled up 1/2 an inch. as far as every other engine i've worked on goes it should be able to slide out. any hints??????
t5stang91 #631623 03/24/2010 2:24 AM
You mention the retainer bolts? Is that for the thrust plate? If so I think that's everything.
58' 3200 235 3-speed/OD
ApacheFiend #631625 03/24/2010 2:26 AM
If the crank is not turned just right the cam will hit a counter balance.
My Blog
Pre '68 Dave #631629 03/24/2010 2:35 AM
Apprentice
Apprentice
i tried turning it over and pulling, maybe i will have to give it a try tomorrow. yes those are the bolts for the thrust plate. thanks alot guys.
t5stang91 #631645 03/24/2010 3:02 AM
Note that the Chevrolet Shop Manual recommends that the crankshaft gear be pulled first. This allows for easy rotation of the camshaft to clear the crankshaft counterbalance weights. Otherwise, the crank has to be rotated to eliminate the interference until the cam gear is no longer engaged with the crank gear.
Hoyt
