| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all, I'm checking all my grounds. I can't find the location of "Engine to Firewall"? Can anyone tell me where to look? I have a new strap but I'm not sure where it should be located. My truck is a 1946 1.5ton. | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | There was none on the 1941 models. Never heard one on a 46 either. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Ok then, besides the Negative Battery cable, what are the other major grounds to check? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In later years, GM recommended a ground strap between the head and the firewall (with radios) - from a bolt/screw behind the distributor to a fender-brace bolt at the firewall.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You can't have too many grounds. I would ground battery/engine, engine/frame, cab/frame. Straps are cheap and easy to install. | | |
